10-02-2022 09:13
10-02-2022 09:13
How to switch off vibration. There is only the possibility to enable soft or strong vibration. I don t want any vibration.
thank you
Best Answer10-02-2022 09:29
10-02-2022 09:29
Hi @kdbqlb those are your only two options for vibrations. If you don't want any notifications from Fitbit, you can refuse permissions for those, so you won't get the vibration or the notifications. Any messages from Fitbit would then not be allowed, but you'd miss those phone calls and texts.
Best Answer10-13-2022 01:18
10-13-2022 01:18
how to do that .
Best Answer10-13-2022 06:25
10-13-2022 06:25
Hi @kdbqlb you can see how to get notifications here - click - so you'd want to do the opposite. You can also put on the DND (do not disturb) which stops all communication, unless you want to allow it - click to read. (Page 19)
