How to wear a Charge 5?
I am thinking of upgrading from an inspire 2 to a charge 5 at Xmas. I find wearing the Fitbit on my wrist uncomfortable and as I work with animals it’s impractical as it just gets in the way. I usually wear it on my bicep with a new strap I bought. Does the charge 5 have to be worn on the wrist for best use or can I wear it higher up? Thanks in advance.
1 REPLY 1
Welcome to the Fitbit community, @eddycurrent!
To check Fitbit's recommendations on how to wear your Charge 5 please hav a look here:
Fitbit - Wear Charge 5
I'm skeptical if wearing your device on your upper arm will give you correct step tracking as arm movement in this section is not as extensive as on your wrist. Also i doubt there will be reliable, if any, heart rate tracking this way.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2, Pixel 4a, Pixel 7
