07-06-2022 21:25
07-06-2022 21:25
Best Answer07-07-2022 03:48
07-07-2022 03:48
Hi, @Mah5254, welcome to the community, your Charge 5 is water-resistant and safe for swimming, getting it wet will not be a problem unless it is damaged. The state of charge depends on what you are doing, for instance using the dynamic or onboard GPS will increase battery drain dramatically. You may be interested in this article Why isn't my Fitbit device's battery charging? which has advice and guidance on charging issues.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer07-07-2022 06:22
07-07-2022 06:22
The device is charging it just isn’t holding the charge. Customer support advised they are aware of a problem and are working on it. Fine, except my device is now useless. I left it in the charger all night. It’s now been 20 minutes and charge has dropped to 50%. In another 20 minutes it will be to zero. Unacceptable!!!
07-07-2022 06:38
07-07-2022 06:38
Try a restart
Best Answer07-07-2022 06:44
07-07-2022 06:44
Best Answer07-07-2022 06:54
07-07-2022 06:54
I have the same problem Thought it was just my Fitbit. Guess there is a problem out there.
Best Answer07-07-2022 07:12
07-07-2022 07:12
Check out the other threads on battery life. Seems that we are all experiencing this and it likely isn’t related to the pool.
07-07-2022 08:14
07-07-2022 08:14
Just spoke with customer service. They ran some test and are sending me a new one .... recommend on calling customer service 1-877-623-4997 great customer service ...very pleased My fitbit charge 5 is only9 weeks old, and I have been in the pool plenty of times since I got it..
07-07-2022 08:28
07-07-2022 08:28
