Hello @Woodneye and welcome to the Community. Do you use an Android or iPhone? What version of the app do you have? You can find this by tapping on your profile avatar > Help &Support. You can try deleting your app, then re-download it. Your Quick Calorie option might reappear.
You are having an app issue, not a device issue. This post should be moved to the correct app forum. This will help bring attention to the issue, if others are having the same problem.
Laurie | Maryland
