05-27-2022 13:35
05-27-2022 13:35
The problem is:
The red bar going up on the sleep page that is supposed to indicate awake is labeled deep, REM or light. The very light-colored blue bar that goes halfway up (REM) is labeled light, etc. Each stage is mislabeled. I'm assuming that the timing, stage and sleep minutes of the sleep stage change is accurate, but I do not know that.
Also I went back as far as December and noted that Fitbit had changed the properly labeled stages displayed on the old Charge 4 and transferred by Verizon from the old Pixcel with Charge 4 to the new Pixcel 6 with the new Charge 5 on is now mislabeled in the same way.
I will greatly appreciate help and advice.
