09-28-2022
04:26
12:36
DavideFitbit
09-28-2022
04:26
12:36
DavideFitbit
My Charge 5 won't sync or connect to Bluetooth. Is the app down?
10-06-2022
12:35
06:42
10-06-2022
12:35
06:42
Hi, thank you for sharing all these details about the inconvenience you've been having with your Charge 5, @Llm456.
I've been informed that you already contacted the Customer Support team for further assistance with this. Let me know if you continue to experience any issue to sync your data.
I'll be around.
10-06-2022 14:07
10-06-2022 14:07
What is the answer to this? Today my Fitbit no long updates the app. (Any update on battery issue?) I’m still charging every 2.5 days)
10-07-2022 05:10
10-07-2022 05:10
Hi my charge 5 won’t pair with the app, please can you help?
10-07-2022 08:58
10-07-2022 08:58
If I understand correctly pairing & syncing are 2 different things. I’m trying to get my Fitbit to send info to the app. I’ve since d figured it out. But pairing is typical of an initial setup.
10-22-2022
08:19
06:42
10-22-2022
08:19
06:42
Hi, thank you for confirming that you've been having the same inconvenience with your Charge 5.
@skw56 Let me know if you continue to have any problem to sync your data. If you haven't done so already, please follow the recommendations listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
@helenmbailey21 Let me know if you mean that you can't complete the set up process. In the meantime, please follow the steps listed here if you're still having this inconvenience. Let me know about the outcome.
