02-06-2023
16:40
07:35
LizzyFitbit
02-06-2023
16:40
07:35
LizzyFitbit
My Fitbit charge 5 stopped syncing suddenly andi have tried all possible methods to make it sync but it is working uptil the code input, when i put the code it says invalid continuously even after i am typing the right code.
This happened to me, too, this morning and I spent 45 minutes. Called Fitbit Customer Service and the same thing happened.
I kept rebooting both my phone and my Charge 5 and I even downloaded the new iOS for my phone and the same thing still kept happening.
If all else fails, do a Clear User Data on your Charge 5. You may need to Clear User Data in order for your phone to recognize it as a new device and start over like that for it to get past the 4-digit code input and successfully pair with your phone.
I hope this helps and works out for you. I'm still trying this method.
Best AnswerA relative of mine was having this issue and had me take a look. They are trying to connect the Charge 5 to an old Android tablet running Android 7, which Fitbit no longer supports. I downloaded Fitbit on my phone, and tried the process there. Same exact thing happened but this time after it failed, it prompted me with an alternative connection method and I accepted. Once this connection was made it prompted me to do a software update. Forgot the fitbit on my phone once the watch was updated, synced with the tablet and it works.
