Well, even though I’m meticulous about keeping my Charge 5 infinity silicone band clean (by rinsing the band and wiping with a microfiber cloth; occasionally using dawn dish detergent) my band became such an irritant that I was unable to use my Charge 5 (even for a few hoursafter not wearing it for over 2 weeks)! I tried the fabric hook & loop band but it was unfortunately too small for my wrist.
So here is what I did:
I plan to use the following cleaning method when needed; meaning rinsing with water and wiping with a microfiber no longer is working.
Hopefully this helpful to those experiencing this issue. Use at your own discretion. As what works for me, may not work for you or be recommended by Fitbit.
Best AnswerSee Wear and Care @SunsetRunner
BTW most skin irritation comes from the band being to tight, trapped sweat, and the resulting build up of bad bacteria.
Best AnswerThank-you for sharing @Rich_Laue, I am aware of the root cause of contact dermatitis and the link regarding wear & care instructions, but what I outlined is what worked which is why I shared my experience.
Best AnswerIt never ceases to amaze me how the device straps are not fit for purpose. I have had three different Fitbits over the years and all have ended up w/ broken straps (replaced free of charge) and/or causing an itchy rash. The only solution Customer Support gives is to “take it off occasionally” when the very purpose of the device is to be worn continuously to monitor usage, step count, heart rate etc. So there is obviously an allergen in the strap material, which reacts w/ sweat and causes a rash. Witch Hazel does help alright but I also apply Vaseline as a skin barrier. Do better, Fitbit!
