06-14-2023 19:59
06-14-2023 19:59
I got a Charge 5 yesterday and it doesn't fit. I have about 9 inch/240 mm wrists and the biggest band on the largest hole does not fit. Is there a third party band out there for men? This thing is girlie sized. My wife doesn't want it. My daughter has one and it doesn't fit my sons or son in law either. Are these bands compatible with any size of standard watch band?
Best Answer06-14-2023 21:35
06-14-2023 21:35
Hi @Laughing_Hyenas there is no larger band for these devices from Fitbit, but you can find a band extender on Amazon that might suit your purpose. Check it out and see what you can find that would work best for you. Third party bands might be available, but there is no guarantee that they would fit the Charge 5 properly. If you order one from Amazon or anyplace, be sure you can return it. The Charge 5 can also be worn with an optional clip - click to see it.
