04-08-2022
07:33
10:47
DavideFitbit
04-08-2022
07:33
10:47
DavideFitbit
No display on watch face except for 5 dots.
04-09-2022
10:47
09:22
04-09-2022
10:47
09:22
Welcome to the Community forums, @Kenzo01.
Thank you for sharing your feedback and this information about the problem that you've been experiencing with your Charge 5.
Before considering other options, could you please confirm if you already tried the restart procedure with the method described here below?
This has been useful for other users experiencing something similar. In addition, you can also try changing to a different clock face and check if you continue to have the same problem.
I'll be around.
04-09-2022
10:47
09:22
04-09-2022
10:47
09:22
I'll be around.
04-11-2022 07:17
04-11-2022 07:17
04-15-2022 06:34
05-22-2022 07:58 - edited 05-22-2022 08:08
@DavideFitbit:Your method for resetting the Charge 5 display, when it displays only 5 LEDs, by pressing the button on the USB Connector 3 times, worked on 1st try. I did not need to try switching Clock Faces. Thank you for your assistance.
05-26-2022
10:50
09:22
05-26-2022
10:50
09:22
Welcome to the Fitbit Community forums, @themezman.
That's great news, thank you for sharing this update. 😁
See you around.
04:23
10:58
DavideFitbit
06-07-2022
04:23
10:58
DavideFitbit
Tried changing clock face and resetting and it did not work. Should I remove and reinstall?
also, not certain it is related, for the last few weeks, it’s been difficult to sync my Fitbit.
Did not work
10:57
09:22
06-15-2022
10:57
09:22
Welcome to the Fitbit Community forums, @PHCharleston.
Thank you for sharing all these details about the inconvenience you've been having with your Charge 5 and for confirming that you already tried the troubleshooting steps suggested.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
See you around.
