11-21-2022
16:40
10:30
DavideFitbit
11-21-2022
16:40
10:30
DavideFitbit
My Charge 5 not showing on screen on iPhone. If I select steps in goes to screen that shows all steps for the past days.
Moderator edit: format
Hi, thanks for sharing your inquiry about the Charge 5 not showing on your app, @Bclewis.
Let me know if you're still having this problem or if you're now able to see your device. If you're still having the same inconvenience, please give one last try to the following steps in the given order:
Hope this helps I'll be around.
