09-26-2022 21:00
09-26-2022 21:00
Is there a way to set a pace goal while using running exercise on a Charge 5? All I see are Time, Calories, Distance, and Zone Minutes. Is Pace goal available under another exercise? Thanks
Best Answer09-29-2022 03:26
09-29-2022 03:26
@Enphoti I'm sorry, but that option isn't available in any shortcut.
Laurie | Maryland
Best Answer09-29-2022 07:28
09-29-2022 07:28
@LZeeWIs it available on other fitbit devices or does fitbit not offer that for all its devices? Any reason you know of?
11:06
12:15
09-29-2022
11:06
12:15
@Enphoti To the best of my knowledge, all Fitbits share similar programming with respect to goals. If you set a distance goal for your run, it will vibrate when you are halfway to your goal and when you reach your goal. The other goals work the same way. If you want to run for 20 minutes, it will vibrate at 10 minutes, then at 20 minutes. You can't program a pace goal when this is the framework of the programming.
When you are using the Exercise app, you can scroll through real time stats in the middle stat. The real time stats include a "spot" pace and and your average pace. You can monitor your pace while you are running and aim for a goal there. But there isn't any way to get vibration feedback that you are running at your desired pace.
Laurie | Maryland
