Hello @MPdriver
You can see if your Charge 5 is connected to the Fitbit App by looking at the Bluetooth on your Android or iOS device. It will say it’s connected or not connected.
Also, if you see that the Fitbit App is showing the data your collecting (steps, calories etc) then that’s an indication you are connected as well.
If your Bluetooth is telling you your not connected try turning your Bluetooth off, wait a few seconds then turn your Bluetooth on.
😃 I hope this provides you with the answer you need. Please let me know.
