01-15-2025 08:37
01-15-2025 08:37
Recently my charge5 calibrated my target/heart load. Unfortunately, this happened to be in a week without any exercise (holidays, family circumstances etc). So now my fitbit has made a calibration in which almost every walk/bike/run (whatever) is calculated as 'too much of an excercise...' Is it possible to REcalibrate my fitbit during a normal week, to get a normal assessment of my workouts?
Best Answer01-15-2025 11:04
01-15-2025 11:04
Hello @TineWinkel
If you can be patient and ignore the "too much exercise" notification, the target load will eventually recalculate as described in this help page (<-- click link).
Although I'm not sure that this will work for what you want to do, the only other option that I can think of would be to delete your Cardio Load data. If you want to try this:
Please let us know what you decided to do and the outcome.
01-15-2025 11:04
Hello @TineWinkel
Best Answer01-15-2025 12:52 - edited 01-15-2025 23:44
Thx for your reply/solutions! I decided to remove the last 6 weeks of hart
load data, but the systems reply was that my request is under ... (sorry,
forgot the explanation) and that it might take 2 months before it will be
effective?! Weird! I 'll wait to see what happens the next days, tbc.
Added: it worked, no heart load mentioned, fitbit tells me to wait 7 days for an accurate reading 🙂
01-16-2025 13:07
01-16-2025 13:07
Hello @TineWinkel
Thanks for the update. Now we know that deleting some of the cardio load data helps to reset the target load. 👍
