07-15-2022 10:19
07-15-2022 10:19
How do I disable the readiness feature
Best Answer07-15-2022 11:50
07-15-2022 11:50
Hi, @SunsetRunner, welcome, you can remove the tile from the "today" screen, touch "Edit" in the top right corner, each tile acquires an "X" >touch the "X" on the Readiness tile and it will be removed but is recoverable from the bottom of the screen at any time by using the "Edit" function. If you touch and hold a tile you can slide them up and down to change its order.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer07-15-2022 12:11
07-15-2022 12:11
