09-10-2023 13:19
09-10-2023 13:19
Received my warranty replacement and have questions about the risk of allowing the firmware to upgrade. Charge 5 as received flashed with 182.26 and working as it should.
How do you determine what version is promoted to load? Is it incremental or the latest version?
Is there a version report available documenting what the updates corrected/added to understand the benefit of accepting the latest update(s)?
Can you shut the updates off?
Best Answer09-12-2023 09:40
09-12-2023 09:40
Hello @Mad_Merckx
You'll know if you have a firmware update from the Fitbit app when you look at the Account page (tap on your picture/icon in the upper left of the Today page). As far as I know, it's not an update that installs automatically. You need to manually click on the firmware update to install it.
I have not seen a version report documenting the firmware changes, although I'm sure it exists somewhere.
I don't think you can shut off firmware updates. However, since they are not automatic, you have control as to when and if they are installed.
Best Answer09-12-2023 10:24
09-12-2023 10:24
Best Answer09-13-2023 18:15
09-13-2023 18:15
You should update ASAP. If you wait too long and the update kills it, it will no longer be covered under warranty. The warranty period starts with the original purchase date, not the replacement date (unless you bought the replacement).
