06-18-2022 18:02
06-18-2022 18:02
Hi, I am wondering if the Fitbit charge 5 can track running laps, I know the Fitbit sense can but I don’t know if the charge 5 can.
For example: I run at a track regularly, and I want to see how many laps I ran because I don’t keep track of how many laps I run.
thanks
Best Answer06-20-2022 11:42 - edited 06-20-2022 12:09
@ShadowNinja Lap counting on the Charge 5 isn't as customizable as lap counting on the Sense/Versa 3. The Charge 5 only has automatic lap counting. if you run on a 400m track, then automatic lap tracking will work. There is a 0.4 km lap available. The shortest mile option is 0.5 miles. It doesn't have the Manual lap option like the Sense/Versa 3. Manual lap count on the Sense/Versa 3 looks like this:
Versa 3 manual lap
You tap the top icon as you complete a lap. The Charge 5 doesn't do this.
Laurie | Maryland
06-18-2022 19:15
06-18-2022 19:15
I'm fairly sure the Charge 5 can count laps the same ways as the Sense, but that might not be what you expect. You set what a "lap" is. It can be measured in miles, km, minutes, or calories. If you select miles, the smallest unit is a half mile. If you run on a quarter mile track, that would be easy enough to figure out, but don't be thinking that it's something that you can tap each time you cross some point to mark a lap.
Versa 3 manual lap
Laurie | Maryland
06-20-2022 12:01
06-20-2022 12:01
I didn't even realize you could tap for laps; maybe I should find out what I am talking about before answering.
