08-03-2022
08:09
09:52
DavideFitbit
08-03-2022
08:09
09:52
DavideFitbit
Hi. Is it possible to reverse the wrist-twisting movement for activating screen wake? I wear my watch face on the opposite side of my wrist (pulse side) to avoid any damage or scratching, and easier to view while cycling. The Charge 5's is set to twists clockwise for the screen wake feature - can it be set to twist anticlockwise?
Hi, welcome to the Community forums, @rayolite.
Thank you for sharing your inquiry about the screen wake feature on the Charge 5.
I've tested this on my Charge 5, but I do see that it doesn't always work if the watch is placed on the opposite side of the wrist. As you mentioned, this could be very helpful while cycling for example.
I recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
Thanks again for sharing all your feedback and comments.
