05-19-2022 19:40
05-19-2022 19:40
I frequently find something running on the watch/tracker after a shower. How can I prevent this?
Best Answer05-20-2022 00:50
05-20-2022 00:50
Hello @Bouchonne
You could try turning on water lock before you go in the shower. Scroll down from the Clock Face screen until you get to Water Lock, tap it firmly to turn it on. You have to tap extremely firmly to turn it on and off, so it's worth practicing before you actually need to do it.
I hope that helps you a bit.
