Thanks...
Then I think I will go for the Versa 3.
Martin.
08:30
13:40
09-24-2021
08:30
13:40
Hi, thank you for your inquiry about the Charge 5, @martin.manders @KelseyClubb.
As you guys mentioned earlier, unfortunately there's no option on the Charge 5 to turn off the tracker completely. This is a feature that is mostly available with Fitbit watches, as you can check here. What you can currently do on the device is to turn off the screen by covering the tracker face with your opposite hand or turn your wrist away from your body. Note that if you turn on the always-on display setting, the screen won't turn off.
Even though this option is not available, I would recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
Have a great day.
I assume it has do not disturb feature like on the Sense and versa. Otherwise that thing would annoy my wife and I all night!
Best AnswerIt is possible to shutdown the Versa as well as the Sense...
Greetings,
Hi, thank you for your inquiry, @mikeyt1818.
Yes, Charge 5 has both Do Not Disturb Mode and Sleep Mode available. You can find more information about these features and where to find them in the Charge 5 user manual.
@martin.manders Thanks for you question as well about the Versa and Sense. Yes, you can turn off both of these watches, you can find the instructions on how to do this in this article.
Have a great day!
Best AnswerHi, I purchased a Sense as well as a Charge 5. The Sense, is being used as my primary device and the Charge 5 as a backup device. I put the Charge 5 on the charger, so it would have a full battery when I shut it down.
But now, I don't see a way to power it down.
Am I just supposed to let the power fade until the device dies?
I'm getting tired of this popup message that appears on my phone, telling me that a Charge 5 device has been found and, do I want to pair it? How can I make that message go away? Please advise.
@PlanoPaul Thank you for your reply and for sharing this information.
As you mentioned earlier, the Charge 5 doesn't have a option completely turn the device off. I would recommend that you post this idea in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
Regarding the message that you're getting on your phone, could you please provide a few extra details? Let me know if this message appears on the screen when you open your Bluetooth settings or if it just randomly appears on your screen.
I'll be around.
12:03
10:00
DavideFitbit
11-21-2022
12:03
10:00
DavideFitbit
Of course there's a way. Plug it into the charger, and don't say you can't turn it on if you don't have the charger, you just don't turn it off if no charger is available. At least you can turn it off! Hello Fitbit?
Moderator edit: format
Hi, welcome to the Community forums, @jgergetz.
Thanks for sharing your comments about the Charge 5.
Let me know if you're referring to the restart procedure that you complete using the charging cable? This will reset the device, but it won't permanently turn it off.
I'll be around.
