05-23-2022 11:38
05-23-2022 11:38
The sleep page mislabels every single colored up and down bar erroneously.
That is the deep blue sleep bar is labeled awake etc. As you know it
should be red if it is awake. The timing (placement and breadth of the
bar) indicating changes from one stage to the other may be correct and
I'm guessing that the sleep numbers (i.e. number of minutes of a particular stage is correct, but I don't know that.
I went back as far as December and every sleep page that used to be
properly labeled on my old Pixel with Charge 4 is now mislabeled on the
Pixel 6 with Charge 5.
After updating to Fitbit version 3.59.1, it did not change.
I will greatly appreciate any suggestions.
Best Answer05-25-2022 11:57
05-25-2022 11:57
RICH _Laue
I really appreciate your answer. Sorry I wasn’t clear.
The problem is:
The red bar going up on the sleep page that is supposed to indicate awake is labeled deep, REM or light. The very light-colored blue bar that goes halfway up (REM) is labeled light, etc. Each stage is mislabeled. I'm assuming that the timing and sleep minutes of the sleep stage change is accurate, but I do not know that.
Also Fitbit went back and every sleep episode I had that was properly labeled and displayed on the old Charge 4 and transferred over from the old Charge 4 to the new Charge 5 on the new Pixcel 6 is now mislabeled in the same way.
You’re right, I have no control.
Thank you.
G
Best Answer05-25-2022 09:56
05-25-2022 09:56
These colors are set by the fitbit developers, the fitbit user has no control over them.
Not sure if what type of suggestions are being asked for.
05-25-2022 11:57
RICH _Laue
The problem is:
Thank you.
G
