05-16-2022
13:34
11:37
DavideFitbit
05-16-2022
13:34
11:37
DavideFitbit
Hi. As my sight is not very good I only can see the main running value (tempo) in the middle of display (bigger font). Other exercise data below and above (in very small fonts) I am not able to focus clearly, while running. Is there any possibility to set an automatic toggle between those values (in running: tempo, distance, duration time)? For instance, all parameters alternating in the main field every 5 seconds.... Thank you.
Best Answer05-25-2022 11:37
05-25-2022 11:37
Hi, welcome to the Community forums, @SunsetRunner.
Thank you for your inquiry about the Charge 5 and the values on the display.
If you haven't done so already, I would recommend that you vote for this idea posted in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers: Make a larger font size available for all stats on Charge 5.
There is no clock face available right now that would toggle between the stats that you mentioned earlier. However, if you have a specific idea for a clock face with this particular design, you can also post your idea separately including as many details as possible in the Feature Suggestion section of the Community.
See you around!
