01-31-2023 16:58
01-31-2023 16:58
Hi, my job consists of a lot of standing and arm movement, I assemble boxes, but my fitbit records my arm movements as steps. I was wondering if there was any way to help adjust the settings so that it would only record my steps as opposed to arm movement. Can I make it less sensitive to movement?
Best Answer02-01-2023 04:21
02-01-2023 04:21
Hello @EGrange and welcome to the Community. If you wear your Fitbit on your non-dominant wrist, you can change the sensitivity by changing the wrist setting to dominant. This will reduce, but not eliminate, these steps.
Laurie | Maryland
