04-30-2022
15:43
06:31
DavideFitbit
04-30-2022
15:43
06:31
DavideFitbit
Steps disappeared after charging.
05-03-2022
06:31
08:33
05-03-2022
06:31
08:33
Hi, welcome to the Fitbit Community forums, @Llobert.
Thank you for sharing this information about the problem you experienced with your Charge 5.
Before considering other options, could you please provide a few more details? When you charged the device, the steps disappeared from the device itself or you're not able to see them on your Fitbit app?
In the meantime, please try restarting your device using the charging cable and sync your device again. In case the problem is related to the Fitbit app, please follow the steps here below as well:
I'll be around.
12:38
11:42
DavideFitbit
05-05-2022
12:38
11:42
DavideFitbit
My husband had over 12000 steps on his Fitbit charge 5 which disappeared after he charged it. We have no idea why that happened, but it was disappointing.
I should add that we tried the restart with no success.
Best Answer05-11-2022 11:42
05-11-2022 11:42
@Llobert Thank you for your reply and for confirming that you already tried the troubleshooting steps suggested earlier.
If the steps were definitely lost, unfortunately it would not be possible to recover the lost steps, but you can manually add an activity to override the data recorded.
In this case, if you continue to experience the same problem, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
See you around.
Best Answer01-21-2023 22:12
01-21-2023 22:12
I've had the same issue - just did 46000. steps and walked 29k. When I synced with my iphone, this changed to 28000k and 18k. I've only just bought this fitbit so this is not ideal. Any suggestions?
06:24
07:20
02-03-2023
06:24
07:20
Welcome to the Fitbit Community forums, @Sorefeet25.
Thanks for confirming that you've been experiencing the same issue with your steps.
Before considering other options, could you please confirm if you already tried all the steps mentioned here earlier? Let me know if you're also having issues to sync other information.
15:49
05:18
DavideFitbit
06-25-2023
15:49
05:18
DavideFitbit
I had initially set the app to sync to my iwatch…via the myFitnessSync. Step count was 1728. Picked up Charge 5 and added as a new device. The device consistently changes from current number of steps to 1768…then when sync…goes back to 1728. Restarted phone and charge 5…no change. Removed charge 5 and re setup…no change. Deleted myFitnessSync and did all same steps over…no change. How do I fix this?
I may have figured it out. I had to unpair the iwatch from the phone. Then reinstall the fitbit device. So far so good.
Best Answer06-27-2023 05:18
