03-03-2022
23:18
08:14
DavideFitbit
03-03-2022
23:18
08:14
DavideFitbit
Charge 5 worked for two days. Now it stopped tracking sleep. It no longer produces a sleep score, and I don’t see sleep stages.
03-04-2022
05:29
08:15
DavideFitbit
03-04-2022
05:29
08:15
DavideFitbit
Mine did not monitor sleep last night as well. Had Fitbit on four 4 days. No data collected.
Rebooted phone and Fitbit works perfectly now.
03-05-2022 08:14
03-05-2022 08:14
Welcome to the Fitbit Community forums, @mion81 @RaPepe.
I appreciate all the information that you've shared about the inconvenience that you've been experiencing with your Charge 5.
Before considering other options, please complete a restart procedure following the steps listed here below:
In addition, please wear your device on your non-dominant hand and monitor it for the next few days. In the meantime, for the nights that don't have sleep data, you can manually log your sleep by going to the Fitbit app, tapping on the "+" icon next to the sleep tile > Add Sleep Log and entering your details.
In addition, keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually
@RaPepe Thank you for sharing this update, it's good to know that it's working properly now!
I'll be around.
Best Answer03-09-2022 04:47
03-09-2022 04:47
It seems every other day or so, the device stops recording heart rate and/or sleep stages, and has to be restarted. That's really a nuiscance. Should I send it back for a replacement?
Battery is never critically low. I always wear it as recommended.
