03-08-2022 20:35
03-08-2022 20:35
I would like to know when i take my fitbit5 off then put it back on after a shower or after a charge it will take 2 to 3 days before it shows anything. What can i do
Best Answer03-08-2022 21:19
03-08-2022 21:19
Hello @Pearldyn
It only measures SPO2 while you’re asleep so it makes no difference to that if you take it off other times.
It usually takes about 3 nights to be able to start measuring and you may not always get a score as it can be a bit temperamental at times.
Don’t be afraid to take your Charge 5 off when you’re awake.
I hope that helps a bit.
Best Answer03-09-2022 03:05
03-09-2022 03:05
Thank you. I would always charge at night i will start to charge during the day
03-09-2022 03:22
03-09-2022 03:22
That's a good idea @Pearldyn
To be honest, it doesn't take that long to charge at all. I put mine on the charger to top up while I'm in the shower each day and it seems to keep the battery level quite high.
