Stopwatch display freezes Charge 5
I want to use the stopwatch to time yoga classes I teach. I need to be able to just glance at the watch and see where I am in the class or how long we’ve been holding something. But I don’t seem to be able to keep the stopwatch visibly running at all times. It seems that if the screen dims the stopwatch display freezes and I can’t get it back to the current timing without either tapping or twisting my wrist which I don’t want to be bothered doing.
I have tried setting the display to always on. And I’ve set the timeout to long (there doesn’t seem to be a no timeout option). But even so the stopwatch display still freezes - the stopwatch is still running – you just can’t see the current time, which makes it pretty useless.
Is there some combination of settings that will keep the running stopwatch always visible without having to move or touch the watch face? It’s not really a stopwatch if you can’t see the current timing without having to do something to the watch.  I understand that will use more power, but that's fine for an hour class a few times a week.
2 REPLIES 2
Hi, welcome to the Fitbit Community forums, @doug493
Thank you for sharing this inquiry about the stopwatch feature on your Charge 5.
I just tried this feature on my Charge 5, but I was able to see the stopwatch while the Always On display was turned on. Could you please confirm if the stopwatch is disappearing after a specific number of minutes? In the meantime, please try restarting your device using the charging cable, as described here
Or let me know if you're not using the stopwatch feature and you're referring to the exercise mode. I did notice that while you're recording an exercise, the stopwatch is visible at the bottom on the screen.
Thanks for getting back to me. I reset using the charging cable as you
asked, then set the Always On display option to on. I didn't make any
other settings changes.
I started the stopwatch and it froze at five minutes. If I double tap the
screen the moving stopwatch returns but then freezes again around ten
seconds later - double tap again, freezes again after ten seconds, etc.
I tried twice and the stopwatch display froze at 5:00 minutes each time.
I come into the peace of wild things who do not tax their lives with
forethought of grief.
*The Peace of Wild Things* – Wendell Berry
