I consistently find Fitbit records that I have walked further than I have. Eg. Today in Hike more it stated I walked 7.55 miles, when I know the distance was in fact 6.2 miles. This appears to be a big issue for Fitbit. But if change Stride Length from its Automatic setting, could this effectively correct the issue? If so do I need to lengthen my Stride Length in the App or shorten it?? Thanks
Best Answer@LaurelSayer Both forms of measurement have their limitations. Every GPS point is approximate, not pinpoint. If you are hiking in a wooded area, the tree cover can interfere with GPS accuracy. On the other hand, a steps x stride distance is accurate with level walking. You change your stride length when doing up and down hills and managing irregular terrain. I personally would not change stride length.
I'm retired military. I know for a fact that I could take the same hike with a small military grade GPS and it won't say that the distance is 6.2 miles.
Laurie | Maryland
