12-20-2021 17:29
12-20-2021 17:29
Have had this less than a month!! I have done the restart. Let it die and charge. Same results. So frustrated!!
Best Answer12-21-2021 01:36
12-21-2021 01:36
When you say it's stuck on the logo, do you mean the setup screen with the logo and text scrolling beneath? If so have you tried removing the device from you account (in the Fitbit app), removing it from your phones Bluetooth settings and then trying to set it up again "set up device" in the Fitbit app.
12-23-2021 08:44
12-23-2021 08:44
Best Answer12-23-2021 13:27
12-23-2021 13:27
I think at this point it's probably safe to assume the device is faulty (bricked) if it's not responding to anything you've tried. I would recommend contacting customer support (here) to discuss which warranty options are available to you.
