04-16-2025 09:46
04-16-2025 09:46
No, I won't setting up a google account just so that I can use Fitbit.
I'll be looking at what functions will work without the app.
Google and Fitbit can shove it up their ricker!
04-16-2025 10:19
04-16-2025 10:19
@Wongster For all intents and purposes, nothing will work well after the deadline. The time on your clock face can drift if you don’t sync over time. If your battery dies, you can’t fix the time after you recharge it. You need to sync to your phone and the Fitbit app to get the correct time. You can’t change time zones or correct the time if you switch between standard time and DST.
Plus, all your data resets at midnight.
Laurie | Maryland
04-16-2025 10:28
04-16-2025 10:28
Thank you Laurie. I appreciate the information.
To the bin for this Charge 5 on 2 Feb next year. If it lasts that long!
Best Answer04-16-2025 10:36
04-16-2025 10:36
@Wongster Please recycle the pebble as e-waste if required by local laws.
Laurie | Maryland
