Tapping on the screen of my Charge 5 doesn't wake it up. Firmly tapping once, firmly double-tapping, short hold, long hold - nothing works. (It's supposed to wake up with a single tap.) Then maybe the 10th or 15th time I try - it might wake up. Restarting doesn't help. Battery fully charged. No change in behavior through 2 firmware updates - same story. When I set it to "auto" - raising the wrist or just waving it - works reliably. Tapping - does not.
Once it wakes up (and then goes back to black), the next tap (within a few minutes) - reliably wakes it up.
Anyone having the same issue?
Thanks!
I might have figured it out: the "wake up" sensor is not in the glass but rather in the device itself, and responds not to tapping - but to shaking.
Try this: tap several times, rapidly - not on the glass ("face") of Charge 5 - but on the band next to the face, see if it wakes up.
This wakes it up for me, every time. (So does rapidly tapping on the face - the point is that the sensor is not in the glass.)
Bottom line:
Thoughts?
