Updating my responses Charge 5
How do I update my responses and emojis in notifications using the fitbit app?
1 REPLY 1
Hi, welcome to the Fitbit Community forums, @Ranga19
Thank you for sharing your inquiry about the Charge 5.
From what you mentioned, it seems that you're referring to the Quick Replies feature that allows you to respond to notifications using text and emojis. In order to update the text replies and the emojis as well, please follow the steps listed here:
  1. Open the Fitbit app and tap on your profile icon at the top of the dashboard
  2. Tap on Charge 5
  3. Tap on Notification and scroll down until you see the Reply Settings section
  4. Tap on Quick Replies
  5. Tap on Default replies or select the specific app that you wish to customize the replies for
  6. Tap on the reply or emoji that you wish to customize/edit
Hope this helps, I'll be around.
