Charge 5 is stuck in Run exercise mode. Tried to uninstall to free up the watch, but there is no option to uninstall.
Best AnswerHello @Tired65
I take it that you tried to end your run workout and it won't respond to your tap.
See if you can restart your Charge 5 using the charging cable that came with your device. If you would like instructions on how to do that, click on this link: How to restart the Charge 5
Hopefully, restarting your Charge 5 will get it unstuck.
Hello @Tired65
Best AnswerHi @Tired65
You're welcome and thanks for letting us know that you were able to fix the issue.
Even though Run wasn't checked as one of your exercise shortcuts, I suspect it is enabled as Auto-recognized. To confirm:
Changing the minimum time to a longer time or selecting Ignore should prevent your Charge 5 from automatically tracking your movement as a Run.
