05-23-2024 17:45
05-23-2024 17:45
Just wondering if anyone else is experiencing any issues with water tracking. I’ve never had any problems before this latest update. Now I go in and let’s say I added 32oz, I’ll open the app a few hours later and it’ll be at 11.3oz. It’s always a number like that, 9.1oz, 18.5oz. I have to fix it multiple times a day and also it will do it to the water amounts for the previous day. For example yesterday I had 104oz. When I went in earlier to add some water for today it was showing yesterday’s water intake at 9.4oz. This is incredibly annoying. If anyone knows any way to fix this please let me know!
05-25-2024 14:12
05-25-2024 14:12
Hello @jsc676
I'm wondering if there's something going on with the units of measure in the app.
Just brainstorming here. You might try changing the units from fluid oz to mls, sync, then switch back to fluid oz, & sync again. If you want to try this, here are the steps to change the units, if you need them:
Hopefully, this might clear out whatever weirdness is going on with your water intake. 🤞
Best Answer05-26-2024 16:56
05-26-2024 16:56
Hey Rieko! Thanks for the suggestion but unfortunately it didn’t work. I switched to mls yesterday and no issues but then today when I opened the app for the first time in the morning I saw that it brought down yesterday’s entry from 3,500ml to 284.4ml and was showing 500ml today even though I hadn’t put anything in yet. Switched it back to oz and still doing the same random thing.
I’ll just use a water tracking app. Thanks again!
Best Answer05-27-2024 11:27
05-27-2024 11:27
Hello @jsc676
Thank you for letting me know that this didn't work.
I'll keep monitoring for a solution and will report back if I learn of one.
