04-17-2024
16:57
07:29
EstuardoFitbit
04-17-2024
16:57
07:29
EstuardoFitbit
My Fitbit arm is in a cast and I can’t wear the device. Any suggestions?
Best Answer04-21-2024 06:35 - edited 04-21-2024 13:32
@Readersue Many users wear their Fitbits on their ankles for various reasons. Some people can't wear anything below their elbows at work. Some will do it while running with a jogging stroller. I've played around with mine on my ankle just to see how well it works. My step counts seem reasonable. I also got my heart rate trace. I would wear it about an inch or so above my inside ankle bone. I have small wrists and skinny ankles. I am able to get a good fit with the large band. Amazon sells third party band extenders. There are several models available.
I had an arm cast many years ago, long before Fitbit. My fingers hurt at first, but I was able to use them more after a little time. You might be able to wear your Fitbit on your other wrist soon. Get well soon.
Laurie | Maryland
04-17-2024 18:17
04-17-2024 18:17
Switch arms, but that's so obvious you must have thought of that.
04-17-2024 18:26
04-17-2024 18:26
Best Answer04-17-2024 20:49
04-17-2024 20:49
Put it in a pocket to still get steps, even if not heart rate or associated metric such as sleep and AZM?
04-20-2024 13:21
04-20-2024 13:21
Hello @Readersue
Sorry to hear about your injury.
What would you like to continue to track with your Fitbit during your recovery? That will help us give you suggestions & options.
Best Answer04-20-2024 15:45
04-20-2024 15:45
Laurie | Maryland
04-21-2024 13:07
04-21-2024 13:07
Best Answer04-21-2024 13:34
04-21-2024 13:34
Hi @Readersue
Although MacGyver often used duct tape to help him out of his sticky situations, I'm not sure that would be the best option for you. 😉
If you want to try taping your Fitbit to your ankle, consider using some kind of medical tape instead. There's paper surgical tape and a self adhesive stretchy bandage wrap that would be good options. Also, the bandage wrap is available in different colors, not just beige. Both are designed to be used on skin.
