01-05-2024
08:24
06:31
CrisVillaFitbit
01-05-2024
08:24
06:31
CrisVillaFitbit
I’ve read all the recommendations for saving battery life. I keep my screen on manual.
is there any information on the faces as to which can help extend battery life? I assume it’s one that uses less colors .. but any suggestions or has anyone tested?
i switched from the HR where I was getting 10 days to this where I get about 5
im also charging at 20% now instead of close to dead which I did not do with my old HR.
i don’t personally like any of the faces . Wish they had something more plain like HR.
Moderator edit: edited title to clarity.
Best Answer01-07-2024 06:33
01-07-2024 06:33
Hi, @Ruby.Soho Welcome to the community.
Thanks for letting me know you're situation in regards to which clock face to use to save the battery of your Charge 5.
My best recommendation would be using the a clock face developed by Fitbit. In regards to the design of the clock faces, my best recommendation would be posting this idea in the Product Feedback board in the community, since this section is regularly monitored by the team of developers. Make sure to post your idea including as many details as possible.
