05-20-2022
10:28
06:13
EstuardoFitbit
05-20-2022
10:28
06:13
EstuardoFitbit
H all, when setting up my Charge 5 it asked which hand it would be worn on. Having a proper watch on my left wrist I selected the right hand. Setup then said this was not an option. So why ask the question? However, I've had it on my right wrist for a couple of days and it seems to be working okay ( step counting etc.)
05-20-2022 18:02
05-20-2022 18:02
I suggest you check the message. I have never seen a Fitbit ask which hand, then say what you selected is not an option. Did it perhaps ask if dominant or non-dominant hand when you were expecting it to ask left or right?
05-24-2022 06:48
05-24-2022 06:48
I know what I saw. But thanks anyway for a response.
Best Answer05-24-2022 07:15
05-24-2022 07:15
@Fenboy Did you see this when you were setting up the ECG? Your Charge 5 will ask you this. It records a Lead I ECG. In simple terms, it's a direction thing. I don't understand why it would tell you that right isn't an option. I can't verify your experience because I gave my Charge 5 to my son in law.
Laurie | Maryland
