11-03-2021
09:05
13:28
AndreaFitbit
11-03-2021
09:05
13:28
AndreaFitbit
I just got my fitbit charge 5 for less than 2 weeks. I have been wearing it to play sports and exercise but today a white line appears on the screen. Unfortunately, the white line just wont go away. Is anyone here encountering the same thing?
Best Answer11-04-2021 02:48
11-04-2021 02:48
Hello, it's a bright white line that got stuck on the screen - definitely not the update download line. Anyway, i got in touch with the customer support and they've confirmed that it is a display issue and will send a replacement. Hopefully it will arrive soon.
11-03-2021 11:35
11-03-2021 11:35
Hi, @jwlow, welcome to the community, provided this is not the update download line (a white single line that is at half screen height and extends from left to right to indicate an update download) you should talk to "Customer Support" here. Use the Chat facility or phone for a prompt response.
I hope this helps.
Cheers
Gr4ndp4 | UK
11-04-2021 02:48
11-04-2021 02:48
11-04-2021 04:22
11-04-2021 04:22
Hi, @jwlow, I'm pleased you have sorted your problem out.
Cheers
Gr4ndp4 | UK
