06-21-2022
02:26
09:26
DavideFitbit
06-21-2022
02:26
09:26
DavideFitbit
Why doesn’t the GPS works ?? Suddenly I cannot see the map . I want to see the place where I run
06-21-2022 09:26
06-21-2022 09:26
Hi, welcome to the Fitbit Community forums, @liseivar.
Thank you for sharing this information about the issue you've been experiencing with your Charge 5 and the GPS route.
If the GPS is getting disconnected during your activity, the Charge 5 may track different information for the the distance. Before considering other options, make sure to follow the steps suggested in this article.
All devices with GPS sensors require a direct path to GPS satellites to calculate location. A weak GPS signal might affect the accuracy of your route and other activity data. Your device uses your step count to calculate distance until it finds a signal, so the total distance calculated for a workout may be slightly less accurate when GPS isn't available for the entire time. In particular, please make sure of the following:
If you continue to experience the same behavior and your GPS is getting disconnected, make sure to try following the steps listed in this article to complete a restart, as this has been useful for other users experiencing something similar.
In case this is a problem related to the Fitbit app not showing you the map, please try the following steps as well:
I'll be around.
