08-27-2021
00:05
14:40
SilviaFitbit
08-27-2021
00:05
14:40
SilviaFitbit
Hi!
I would like to know if Charge 5 will finally have a function to sync Smart Alarm / WakeUp with my phone alarm? The wrist vibration never wakes me up and I need an alarm with sound.
Best Answer08-27-2021 03:44
08-27-2021 03:44
Yes, it does. On the Charge 5 product page it says it has Smart Alarms/Smart Wake.
08-27-2021 03:44
08-27-2021 03:44
08-30-2021 02:40
08-30-2021 02:40
This does not answer my question. Im using Charge 3 which has SmartWake function. But thats useless since only vibrates the tracker and Im a sound sleeper and vibration does not wake me up. My question is:
Does Charge 5 Sync SmartWake with Phone alarm so I might have SmartWake with sound alarm from the phone.
Best Answer08-30-2021 06:19
08-30-2021 06:19
@Ziga No, that is not possible. None of the Fitbits have that function.
Best Answer08-31-2021 01:56
08-31-2021 01:56
@Heather-S Well not impossible its just a matter of Software and permissions you give to the app/phone. Device communicates with phone ergo if you could send/recieve SMS and notifications Charge could also send command to phone to start alarm at specific time (best wakeup window)
08-31-2021 10:37
08-31-2021 10:37
@Ziga I mean, it is not possible with Fitbit in its current state because it is not a feature they have for any of the devices. In the future? Maybe. But right now, no.
If you'd like it to be, you should suggest it over on the Feature Suggestions board. 🙂
