strap problem
Tried to remove strap to change to the longer one. Broke the piece that holds the strap on. Any way I can fix that?
1 REPLY 1
Welcome to the Fitbit community, @RJCMRC!
As this part shouldn't brake by normal daily use, I'd suggest contacting Fibit support to check if this is covered by Fitbit's warranty:
Fitbit Support Contact
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Versa 4, Charge 6, Aria, Aria 2
