10-26-2023
11:36
14:02
LizzyFitbit
10-26-2023
11:36
14:02
LizzyFitbit
Having had Charge 6 for a week battery life is about a week. What’s going on?
Best Answer10-26-2023 11:37
10-26-2023 11:37
Battery life a day NOT a week!!!
Best Answer10-26-2023 14:44 - edited 10-26-2023 14:45
If it lasts only a day you should contact customer support. I'm testing battery life now and since full charge it's been 3 days and 22 hours with 5h30m of exercise (3h30m of running with GPS in 'Phone' mode and with Always-On display during exercise), SpO2 enabled. Right now, the battery percentage shows 50%. There must be a problem with your Charge 6.
Best Answer10-26-2023 16:44
10-26-2023 16:44
Hello @KKW51-54
I agree with @Triletics . Your Charge 6 should typically last more than a day. You might want to check to make sure that your device doesn't have some of the power draining features turned on. This help page has tips on which features to disable: Tips to extend Fitbit battery life
If your device continues to drain in about a day after you make changes, you should contact Fitbit support (<-- click link)
