How to set up 24hr clock format?
ANSWERED
Is there a face with a 24hr clock setting? I was running down to the emergency room with blood and the new watch threw our times off in a stressful situation.
1 BEST ANSWER
Accepted Solutions
Hi @OtisRunnee you try using the default watch face and setting it for 24 hours? click to read how to change the time
Stepping in the U.S.A. since September 2013. Android 14
3 REPLIES 3
@Odyssey13 Thanks for your input and the advice. Yes, the clock format is related to the setting and not the clock face itself.
@OtisRunnee Welcome to the forums. Thanks for your post about the clock format on your device. I am sorry to read that the time format caused an inconvenience. There are settings to change the clock format on your device. Please follow the instructions on the article shared above by @Odyssey13. That way you will be able to change the clock format for every digital format clock face.
Got it. I did check and it works with the "Target" watch face as well. I
now have "date and time" for my evening shift.
-Otis
