07-01-2025 04:59
07-01-2025 04:59
It looks like the ability to do this has disappeared since I transferred over to Google. The forums all suggest
Best Answer07-18-2025 12:59 - edited 07-18-2025 13:01
Okay! Another responder had the answer! Copied and pasted here with additional steps/edits added:
1 In the app click on ‘you’ at the bottom or your google icon in the top right corner (the google icon worked for me)
2 Click on fitbit settings in the window that pops up
3 Scroll down to nutrition and weight
click on goal weight
usual choices from there.
Shout out to Hickles for finding the path. 🙂
07-18-2025 12:51
07-18-2025 12:51
I switched over to google today and am also frustrated with not being able to find familiar settings, specifically setting a calorie deficit. Also frustrating is finding instructions in the community section for settings that don't actually exist.
09-07-2025 06:36
09-07-2025 06:36
Do I need to switch to Google for this? I know the old path but I am running into the same issue.
Best Answer03-06-2026 07:08
03-06-2026 07:08
I think it is gone. I have been trying to do it and all I can do is add in the # of cal I want to consume.
Best Answer03-06-2026 07:43
03-06-2026 07:43
Hi @Hopefolan You must set up a food plan in order to set a calorie deficit. It doesn't require switching to Google. This expanded Help article shows the path for both Fitbit and Google accounts. iPhone users can set a calories to consume goal without a food plan. Do you use an iPhone? If so, that explains it.
Laurie | Maryland
Best Answer03-06-2026 08:04
03-06-2026 08:04
Hi everybody, Thanks for stopping by, I hope you're doing well.
Let me clarify some details about this topic.
The google migration did make a change of the path to follow to do these adjustments.
If you have already migrated:
If you haven't migrated:
08:09
08:55
DavidFitbit
03-06-2026
08:09
08:55
DavidFitbit
I have tried all of these options. The only thing it lets me do is change the amount of calories that I want to take in. It will not let me do a deficit. It continues to revert back to the original deficit
My app doesn't have anything that says today I just have a profile picture
Hope Folan, LICSW
Moderator edit: merged reply
03-10-2026 15:59
03-10-2026 15:59
I have walked through these steps repeatedly today and it keeps automatically switching back to a goal of 1,500 intake, vs. the deficit number I have selected. My phone and app are both up to date. Is this a bug on FitBit's end?
03-12-2026 06:09
03-12-2026 06:09
I am having the same issue, I’m able to go through and select the calorie deficit and then it automatically just switches back to a set number! Very frustrating as on workout days I like to get more and on recovery days go with less as I burn much less! Hope they fix this soon!
03-12-2026 12:58
03-12-2026 12:58
Hello everybody, Thanks for your posts, I hope you all are doing well.
I'm sorry to hear you are experiencing an issue while trying to edit your food plan.
Thank you for letting us know about this issue. Our development team is aware of it and they are working to identify a resolution as quickly as possible.
I'm sorry for any trouble. I appreciate your patience and we look forward to getting you back on track.
03-12-2026 19:33
03-12-2026 19:33
Happy to hear you are working on it. I thought I was going crazy but at least I know it’s not just me. I choose calorie deceit but it just reverts back to number of calories.
