Can't Change Charge 6 Watchband
The watchband that came with my Charge 6 is causing a rash (as has ever other watchband for all the other Fitbits I have owned).  When I tried to remove the top band took several attempts before I could take it off.  Once successful I tried to add the cloth watchband I have used on multiple other Fitbits, but it would not stay attached.  I tried it on the bottom it attached perfectly.  I repeated this process with multiple other bands with the same result.  When I tried to reattach the original band, it would not stay attached either until I wiggled it around and then I heard a click, and it attached.  I took it off and tried this with the other bands, but that did not work.  Again, this is only on the top of the Fitbit, so it is not a problem with the bands, but the clip itself.  Even though this one is less than a month old, I cleaned it thoroughly to make sure there was no dirt or gunk interfering with the mechanism.  I don't to waste the warranty for a return - especially since I got the extended warranty - as I know that they only cover the replacement for a year, but if I can't wear the device because it causes a rash then I am stuck.
3 REPLIES 3
@DaRealBigDaddyG were your other bands purchased from Google or from an authorized retailer? Official Google bands for the Charge 5 and Charge 6 are interchangeable. Bands from third-party sellers may not be.
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
The bands all work on the bottom of the Fitbit but not the top.  And, as I noted in my original post, I had to struggle to even get the original band to reconnect it.  So, the issue is not with the bands but the connector itself.
@DaRealBigDaddyG If you think there is an issue with your Fitbit device or Fitbit bands that you purchased from Google, you may want to contact Customer Support for further assistance.
You may also find this thread useful.
