01-14-2024
04:05
08:07
FatimaFitbit
01-14-2024
04:05
08:07
FatimaFitbit
I charged my watch on 3 days ago and this morning it is back to 15% so needs charging again. What could be causing this?
01-14-2024 05:22
01-14-2024 05:22
Hi @Shelly.Nix
If you haven't already done so I would recommend restarting your Charge 6 to see if that fixes the excessive battery drain.
Also do you have the always on display (AOD) active? As that will eat into battery life significantly.
01-14-2024 10:17
01-14-2024 10:17
Mine lasts 6 days ish but if it runs out of battery it then won’t show any of my data.
01-14-2024
19:00
17:02
ManuFitbit
01-14-2024
19:00
17:02
ManuFitbit
Mine did when I first got it but I need to figure out which settings to disconnect for longer life.
Shelly.Nix, I’m having the same challenge, I think it’s the apps that are activated on the watch wish there was a cheat sheet.
01-14-2024 23:03
01-14-2024 23:03
The sp02 app will be quite a battery drain. So if you are looking to save battery and you don't care about spO2 measurements, it's worth uninstalling this. Also as I mentioned above always on display is a huge drain, so disable that and use the raise to wake gesture instead.
02-05-2025 18:26
02-05-2025 18:26
GPS uses a lot of battery and the thing that uses GPS is the Auto Recognized Exercises.
Go to Settings -> Peferences -> Exercise -> Auto Recognized Exercises
If you don't care about having your Charge 6 figure out which exercise you are doing then set each of the 7 exercises to Ignored. Making this change more than doubled my battery life.
The way I look at it is if I'm walking, I already know I'm walking and having the Charge 6 tell me I'm walking... well, duh.
02-06-2025 06:39
02-06-2025 06:39
Hi everybody, thank you for the contribution to the community!
You can find additional tips on how to improve battery life in our help article Can I extend my Fitbit device's battery life? below the section "What are tips to extend my Fitbit device's battery life?"
In effect this one talks about features such as SpO2, GPS and always-on display.
Best Answer09-12-2025 08:23
09-12-2025 08:23
You are lucky then mine doesn't even last 1 day never mind 2
09-12-2025
19:36
15:58
ManuFitbit
09-12-2025
19:36
15:58
ManuFitbit
That’s what mine is doing currently. I have to charge it every other day it seems - if not sooner. And I have my screen display off. Notifications off. Apps off. I’m just using it for step count and sleep at this point and even then it’s failing me because it keeps dying. It’s fully updated. I don’t understand wtf is going on
I charged it for the past few hours, just unplugged it no more than 20min ago and it’s at 61% even though it was fully charged when I unplugged it .. again .. no more than 20min ago.
Best Answer09-13-2025 13:51
09-13-2025 13:51
Hello @Ashly344
When my Charge 5 started having rapid battery loss, I restarted and recharged my device multiple times over several days. As soon as I saw a rapid drop in battery, I restarted my Charge 5 and put it on the charger until it was back to 100%, often doing this multiple times in a day. Eventually, this process got my device "unstuck" and the battery went back to lasting 6-7 days. Although there's no guarantee that this will work for your Charge 6, it might be worth a try.
09-14-2025 03:18
09-14-2025 03:18
I've been having the same problem with my Charge 6 (activated on Nov 18 in 2023) since the last update. I've uninstalled all the apps, had manual mode on the display, uninstalled the Fitbit app off my phone, restarted my Charge 6, and even removed it from the app and tried adding it again. Done pretty much everything I've seen on here to try and fix it. I thought I had fixed it one time, since the battery life wasn't being sucked away, but that lasted a whole day before going back to the battery dying within 1.5 days.
So the other day I found out that for some reason, the app wasn't connecting to my Charge 6 thru Bluetooth. Which it should have been the whole time, since It's how the device should connect. Even though my phone (S20 Ultra 5G) was still getting heartbeat data from it. So the app asked to pair with it and was at 75% battery life on Thursday after I had just pulled it off the charger and as of today, Sunday, it's at 31%. Which is about the 12 to 15% drain that is normal for it. I'm hoping this isn't just another one-time fluke and it keeps the battery life it should.
Though the Fitbit app is still having an issue where it gets about 90% thru the sync process and just sits there. Closing the app and opening it again is the same issue. Restarting my phone did fix it. I have a feeling the app is having a coding issue since it would just get stuck in Sync, even if my phone hasn't been restarted for a week. This is only a new issue since the last firmware update. One anomaly did pop up when trying to remove my Charge 6 before I did remove the app from my phone. Got an error message saying it couldn't complete the process (or something to that effect). Which is also something that shouldn't be popping up at all if the app was working as intended. I haven't checked if this is still a problem yet, since I've been keeping up the updates for the Fitbit app whenever Google Play has one available.
11-02-2025 22:52
11-02-2025 22:52
I'll try this (have the same phone). Battery was 86% this morning, got a warning that it's 20% at 5 pm and a minute later is dropped to 7%.
I have charge 6 since 2023 and never had this issue before. I didn't change any settings, so I suspect this is a problem on their software end.
Well, this is my last Fitbit ever for sure!
Best Answer12-28-2025 15:04
12-28-2025 15:04
Did you ever get that fixed? I just bought mine in march..it would last for days then literally out of no where the battery started to drain REALLY FAST. I haven't worn it in thr last month because it was so **ahem**ty. Just put it back on today and seen it had an update. It's been off charge for maybe twenty minutes and only down to 84 but still...it never did that before...and I can't use warranty because when I bought it at Walmart and PICKED IT UP AT WALMART, apparently it came through a 3rd party seller so now warranty is void. I'm livid.
Best Answer12-28-2025 15:26
12-28-2025 15:26
Nope. There is nothing that could help. But since I ordered my Charge 6 from Fitbit, they are replacing it. Asked me to send everything back (including the charger and bands) but sent back only the tracker. Then asked to send it back again, so they can send me the full kit. But I have to say it didn't cost me anything and I'm just happy that it's getting replaced.
Best Answer12-28-2025 15:46
12-28-2025 15:46
Yes, I solved my fast battery discharge.
Click your initial in the upper right corner of the app.
Select Fitbit Settings
Select Activity
Scroll down and check Activity Detection. If it is Off, I can't help you but if it says "7 activity types" (or something similar), select it and on the next page, turn it off. You can try turning off all the individual exercises except one but I haven't tried that so it may not fix the problem.
Best Answer12-28-2025 16:17
12-28-2025 16:17
I never got mine fixed as well. The battery or the connections on the inside must have gotten compromised. Then to make matters worse, the screen popped off one day when I was working outside. It still works and put it back together, but I have to charge it daily to make sure it doesn't randomly die once it gets below 40%. Doesn't even notify me all the time when the battery is about to die. I just buzzes, flashes the Fitbit logo, and then won't turn back on unless I put it back on the charger when I get back home.
I'll likely get another one if I don't want to deal with the issues anymore.
