12-15-2025
05:02
05:34
MaCrisGBFitbit
12-15-2025
05:02
05:34
MaCrisGBFitbit
My charge 6 keeps going from over 90% battery straight to critical battery level - the same on the watch and the app.
When i connect the charger and restart, both the watch & the app return to over 90%. This keeps happening every few hours.
I guess the charge 6 is wearing out but I am waiting for the charge 7 to be released next year.
Is there any way to fix this?
Thank you..
Hello @PabloPP! Welcome to the forums!
Thank you for letting us know that your Charge 6 is running out of power faster than expected.
I suggest you perform a restart and charge your Charge 6 plugged into a PC and use the tracker as usual to verify the charge.
Hi @PabloPP! Thank you so much for your reply.
We have tried all possible steps through this channel to try to resolve this issue. My best suggestion is that you contact technical support directly, as they have more tools to provide you with the appropriate follow-up.
Best AnswerHello @PabloPP
When my Charge 5 started having rapid battery loss, I restarted and recharged my device multiple times over several days. As soon as I saw a rapid drop in battery, I restarted my Charge 5 and put it on the charger until it was back to 100%, often doing this multiple times in a day. Eventually, this process got my device "unstuck" and the battery went back to lasting 6-7 days. Although there's no guarantee that this will work for your Charge 6, it might be worth a try.
Hello @PabloPP
Thanks for letting us know that you're seeing a little improvement in your battery life.
There's an unorthodox method that might help. A user exposed their Charge 5 to freezer temps. This process helped reset & restore their device. This thread (<-- click) explains what the user tried. It's worked for some, but not all users. Although there's no guarantee that this will work for your current issue, it might be worth a try.
