08-19-2025
04:35
09:12
MarioSFitbit
08-19-2025
04:35
09:12
MarioSFitbit
My new Charge6 says it needs to update. I follow the directions but then get message that it can't update-either try again or try later. It fails every time i try. Phone and fitbit are connected, fitbit is charged, Bluetooth is on, permissions are all ok. What to try next?
Moderator edit -updated subject for clarity
Best Answer08-19-2025 10:44
08-19-2025 10:44
@SAnder59 , A warm welcome to the Community! Thank you for your message and efforts.
Do you get the message when connected to the WIFI or also when connected to mobile data?
Have you tried the steps and tips described here: Why can't I update my Fitbit device?
08-20-2025 09:01
08-20-2025 09:01
Best Answer08-20-2025 09:29
08-20-2025 09:29
@SAnder59 ,Thank you for your reply and further information.
Please sync your Charge 6 to avoid losing recorded data. Make sure no other Bluetooth device is connected to your phone or nearby.
Go to the app. From there, try setting up the tracker as a new device.
Once the Charge 6 is paired to the account again, use it normally until the update banner appears again.
