08-14-2025 22:26
08-14-2025 22:26
So my sleep duration is being tracked accurately but the schedule is off - same for steps - it’s monitoring the correct steps per hour but it’s saying the wrong hour - I’ve changed time zones by 1 hour - I’ve tried restarting the device and resyncing but no luck. See pictures I actually started sleep around 9.42
Best Answer08-15-2025 12:47
08-15-2025 12:47
Hello @Clokeg
By any chance, did you recently travel or use a VPN network? I've read user posts that mention using a VPN can mess up the time in the Fitbit app.
You said you've already tried making a change to your timezone, but that didn't work. Is your location & timezone still set to automatic?
Best Answer08-15-2025 21:36
08-15-2025 21:36
Yes I have travelled to Malta from uk and yes I did have a vpn on and yes I did have it set to automatic time zone. I’ve turned both those off but it still not showing correctly after syncing 😢
Best Answer08-16-2025 11:27
08-16-2025 11:27
Hello @Clokeg
Thanks for the additional information. What you shared sounds to me that something in the app is still stuck either on your travel timezone or VPN setting, even though you turned both off.
The easiest troubleshooting step to try is clearing the cache for the Fitbit app on your phone. If you clear both cache and data, you'll need to log back into the Fitbit app.
If that doesn't work, try uninstalling, then re-installing the Fitbit app on your phone:
Please let us know if this fixed your reported time in the app.
Best Answer08-16-2025 21:30
08-16-2025 21:30
It didn’t sort it- interestingly when I go to vpn settings although I disconnected Norton it won’t let my toggle off the main vpn status button
Best Answer08-17-2025 14:05
08-17-2025 14:05
Hello @Clokeg
Thanks for sharing your screenshot. It's likely that the VPN status showing connected could be causing your time issue.
When you figure out how to toggle VPN off, please let us know if that fixed the time in your app.
Best Answer08-17-2025 22:01
08-17-2025 22:01
So I managed to turn all the vpn off - uninstalled the app, turned my phone off, then reinstalled and still the issue remains
Best Answer08-18-2025 13:23
08-18-2025 13:23
Hello @Clokeg
Now that you were able to turn off VPN, have you tried manually selecting your timezone/location in the Fitbit app to see if that works? If it does, I'm not sure that this will correct the time for your historical workout data or sleep. So, those might show the time incorrectly.
If that still doesn't fix the time display in the app, I'm at a loss at what else to suggest.
Best Answer08-18-2025 21:10
08-18-2025 21:10
Thanks for your help - I tried all that, but to no avail - interesting it wouldn’t let me select the country I’m in - the tick appeared momentarily and then disappeared
do you know how I contact Fitbit support direct?
Best Answer08-19-2025 13:42
08-19-2025 13:42
Hello @Clokeg
That's so strange that your country won't appear in the list.
This is the link to Support (<-- click). Complete the prompt in Step 1. Tap Continue in Step 2 (ignore the Resources) to get to Step 3 which has the contact options.
By any chance are you in the UK? If so, I have a phone number for Support that is several years old, but I think it still works.
Best Answer08-19-2025 23:05
08-19-2025 23:05
Thank you so much - I’m not in the Uk at the moment as I’m on hold but doesn’t look like this will be sorted until I get back anyway
