05-09-2025
12:50
06:55
DavidFitbit
05-09-2025
12:50
06:55
DavidFitbit
Got the charge 6 a few days ago. Kind of buggy with its connections, probably in part because I’m using an iPhone.
Anyone have any luck recently with getting google wallet set up on it. Mine starts to register and then stops and says “an unexpected error occurred. Please try again later.”
Tried resetting everything and setting up using an android phone (9a), but that didn’t work either.
Seems to be a widespread issue that sometimes just resolves for people and not for others. Wondering if anybody else found a workaround. Thanks
Hi @itadori98, thanks for stopping by, I hope you're doing well.
Let me help you setup your Google wallet on our Charge 6.
First, please note that Google Wallet for Fitbit may not yet be available in your region. We are working on expanding the availability of Google Wallet for Fitbit. for reference see Where you can use Google Wallet
If your region is supported, check our help article What should I know about using my Fitbit device to make contactless payments? > How do I set up contactless payments?
